The water does not shut off when it fills
In order to use it you have to push in
The knob and rotate to next cycle
Or else the water just keeps running till it floods the room.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gsq9300eq0
Since you can stop the water by moving the timer, I would say the problem is with the water level switch system.
This switch (Item 12 in Section 2) is actually a pressure switch. It has a tube (Item 19 in Section 3) that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch’s set point then the switch activates turning off the water and starting the agitate.
Possible problems.
- Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
- Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
- The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
Note: That you may be able to stop it by blowing into then tubing and it may still be no good as it needs too much pressure to activate the switch.
So if the tubing is OK replace the switch.
