Jenn Air buttons not working
Hi,
I have a jenn air model SVE47600B. The 4 buttons on the membrane that control the oven no longer do anything. When pressed, there is no beep, and no action from the oven itself. The other membrane butons work normally. Is there a way to ohm out the membrane to verify that it is ok, or do I have to assume that because some of them work, it is the circuit board behind the membrane that is the issue?
It can be tested with an ohm meter or continuity tester although finding the connection matrix to do the testing by is often something else. With any luck it might be printed on the range’s wiring diagram. Have a look.
[B]LINK > http://www.appliance411.com/data.php?ap=AP4088736[/B]
JFYI
Dan O.
http://www.appliance411.com/parts/?ref411=Jenn-Air+Range*The Appliance Information Site*
=D~~~~~~
