Jenn-Air Clock Problem
The clock display dimmed and then went out. Replaced the clock and now oven does not work properly. When set to Broil, shutts off as soon as oven door is opened. Tried two additional new clocks all the same. When old clock is installed oven works fine just no display. Replacement clock PC board looks different than new clock PC board. How can I find correct replacement clock?
Adrian
