I have a Jenn-air oven that occasionally, when using the oven, the display goes blank and the oven quits heating. It doesn’t seem to matter what the oven temp is set to. It will come back on after a few minutes. The clock needs to be reset every time.
I guess this is a unique problem. I was thinking it was the control panel. Does anyone have any ideas?
— Begin quote from drbulloc;191240
This is the second time I’ve asked for help with this problem with no response. I am submitting this wrong?
It appears that I should replace the electronic clock control/display. Not the relay board. CORRECT?
