jenn air dishwasher won't run
my jenn air DW won’t run. It is a touch pad panel with lights, and the normal cycle light is lit. But when I shut the door, the wash light comes on and the DW just sits there, no waterfill can be heard, and it does nothing.
I manually filled some water in the tub, and tried it again, to see if it would pump out the water before it started, and it did nothing. Wash light and normal cycle light are on, but nothing happens. Once, when I tried the same thing, those same lights were flashing, but usually, they are steady.
Don’t have a repair manual, but are there any maintenance procedures to reset the timer/etc.?
Thx
Bob
