Jenn Air Dw Won't Run
The normal and wash lights come on, but the DW does nothing.
Checked to make sure the float was not stuck- no help. As a test, I filled the tub manually, and it still will not run on any wash cycle- light, normally, and heavy.
Any tests I can run- float switch, fill valve, etc?
Why wouldn’t the DW first pump out the water in the tub before beginning the fill?
It just sits there.
