jenn-air double wall oven no display power problem
we had a power outage recently and afterwards the oven display no longer works and the oven itself does not work. I checked the circuit breaker, it had not tripped, but I turned it off and back on again. That did not help.
This weekend I pulled the oven from the wall and removed the top and back sheet metal exposing all the electric thinking I might find a fuse or something that had blown on the oven itself, but I was not able to find any obvious electrical component failure with upon visual inspection.
Any ideas? Any specific places to test with a meter?
Thanks in advance.
