I have a Jenn-Air electric stove/oven model JER8785QAB that was installed in my home when built in 2005. I never had a problem until this month. All of a sudden it will not bake. Everything else on the unit works fine. set the temperature to 400 and it never rose above 150. I checked the lower (baking) element and it is cool. The broiler element kicks on and off as it is supposed to. I tried the warming tray feature and the lower (baking) element heats up properly. I also pulled it and checked for continuity and it registered in the upper 20’s. I first replaced the long oven temperature sensor with no success. There are no visible signs of wear or blackening on any connections on the back of the stove. I have now replaced the clock/control board and still no success. Any suggestions?
Related topics
HELP.....I'm Lost | 1 | 791 | February 23, 2012 | |
JennAir oven will not bake | 4 | 2134 | November 20, 2012 | |
Oven wont heat!!!!!!! | 3 | 1869 | October 20, 2009 | |
Oven will not bake | 0 | 2065 | November 12, 2007 | |
Lower bake element not working | 0 | 1345 | April 23, 2010 |
