I have a three year old Jenn Air electric oven which wont heat. The stove works fine but the oven will not reach the desired temperature. When I set it to a certain temperature I just hear a bunch of clicks but the temperature remains at 100 degrees. Is this a quick and inexpensive fix or am going to have to buy a new oven? Any advice help would be great. Thanks. Lucas
A Model Number may help others help you.
This may help you find it.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Check that both the bake and broil elements work.
Here are the parts
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169951&diagram_id=1329588#d1329588
Here is a tech sheet and a service manual
http://www.servicematters.com/maytag_library/docs/16027223.pdf
http://www.servicematters.com/maytag_library/docs/16025644.pdf
I would check the element first, should be aroun 20 ohms.
See the manual on how to remove it.
Note: I always attach something to the wires before undoing the element so they do not disappear back into the unit, clothes pins work.
