Jenn Air Fault Code F5
Oven heated to 400 degrees, beeped indicating it was up to heat, then shortly after, beeped repeatedly, and showed an F5 fault code and oven shut down.
I restarted the oven, and this happened several times before it stayed up to temp., and I was able to use it.
I called Sears, and they are not able to come out for a week.
Question: can I continue to try to use the oven, or should I remain "ovenless" for a week, until Sears can look at it?
Any suggestions would be greatly appreciated. Thanks
You probably can use it if it will work.
My question is: would you like to diagnose and fix it yourself or you would prefer to pay big $$$ to Sears? And why Sears? Any small local company can do it as well for much better price.
Thanks for the info. We bought the stove from Sears, which is why I went to them, though your suggestion to find a local repair guy is a good one.
I doubt I can fix it myself - not particularly "handy". I did get a suggestion to flip the breaker for 10 min., and the computer may reset itself. I’m trying that. If that doesn’t work, I’ll find someone to look at it.
I appreciate your suggestions, and am glad to hear that it is not dangerous, at least. Thanks
You are welcome. Keep us posted.
