Oven Wont Heat. Broiler And Cooktop Work So Gas Is Fine. I Think The Ignitor Is Gone For 4th Time. It Goes Every 2 Years It Seems.
I Have Had It Repaired Each Time And It Costs Over $200.
I Want To Know If This Is An Easy Install And Where I Find The Instructions. Husband Is An Electrical Engineer!! I Found The Part On This Site For $40.
Replacing an oven ignitor is generally pretty straightforward if you’re relatively handy. Here are a couple of articles that give instructions – if you’re not comfortable once you’ve looked through them, then hire a pro!
