I have a Jenn-Air wall oven, when you turn the thermostat on the igniter glows but doesn’t open the gas valve. I recently replaced the gas valve but it still did the same thing. It looks like a simple circuit that goes from the thermostat, to the igniter,and to the gas valve. There is gas and voltage to the valve. Could I have gotten a bad replacement valve or could it be something else?
Related topics
no gas flow on Jenn Air range | 0 | 1338 | August 23, 2008 | |
Jennair oven | 10 | 1927 | September 28, 2009 | |
Jenn Air gas oven won't heat | 0 | 3293 | November 19, 2007 | |
no gas flow on Jenn Air range | 0 | 1358 | August 23, 2008 | |
jenn air wall oven not working | 0 | 1733 | August 1, 2008 |
