jenn-air oven display blank but oven works fine
oven fine but no display
think it is the display board or oven electronic control or ???
please advise as to the item needed and a part number
Thank You whomever you are
Those are one and the same part. It is likely the problem.
LINK > http://www.appliance411.com/data.php?ap=AP4089341
JMO
Dan O.
http://www.appliance411.com/parts/?ref411=Jenn-Air+Oven*The Appliance Information Site*
=D~~~~~~
thank you for your help
I can’t figure out how to remove the fan blade from the evaporator motor located in freezer department. No set screw.
