Jenn-Air oven will not bake, only broils
Our Jenn-Air suddenly stopped baking in normal and convection modes; the broiler works fine. When set to bake the broiler kicks on for a short while then shuts off. I removed and tested the bake element with an ohm meter and got a reading of 20 ohms. What other things should I check and how?
Apparently no one here.:confused:
GE Profile JBP79CB4CC clock work,cleans on on the boiler, just will not bake./…
Pro Cleanse
