Hello. My dishwasher won’t fill. After looking around, I read that the water inlet valve is a common culprit, so I ordered one from here and just put it on. The dishwasher still won’t fill.
Water is definitely getting to the valve, and when I took the old one off, the line to the dishwasher had water in it, so it seems the valve was okay.
Thanks in advance
Why not to check this switch for continuity? Also check for 120V coming to the water inlet valve while the timer calls for water.
The following article on our forum will explain in detail how to run a continuity test – How to check continuity with Ohmmeter.
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE5500AYQ
And here is a service manual
http://www.servicematters.com/maytag_library/docs/16023110.pdf
If you cannot diagnose/clear it using the diagnostics then:
Unplug the unit
Open it up
Clean the edge connector.
If this does not fix it check the keyboard with a meter.
Just a good idea to make sure the keypad is good, if it is then odds are high that it is the control board.
