Jvm141obc001
a piece of the door latch broke
maybe what holds the spring tension (key)
so the latch hooks have no tension to hold door closed and start microwave
You have to take the door apart to find out exactly what is broken. If this is the door latch itself then it can be replaced. If the spring holding pin on the door frame broke off then the whole door has to be replaced.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216863
— Begin quote from Gene;380119
Here are the breakdown diagrams and Replacement parts for General Electric JVM1410BC001 Counter top microwave | AppliancePartsPros.com
Thanks for your help ,would that be part#1800 the hole door together, just to make sure I order the right parts
Yes. This is correct.
