please need information about installing ice maker which is included with the refrig. mfg#P1196710WL The directions mentioned a plate water valve to be connected
thanks
kaddman85@yahoo.com
Can you be more specific on the problem? I’m afraid I did not get it clear.
According to the model number you posted the ice maker should be already there. If it’s not, then I need the part number for the ice maker you are going to install. Also you’ll need the water supply line to the refrigerator. Do you have it?
No wash cycles will start. We get a flashing "dl" and "f" code. Do you know which control board needs to be replaced? Thanks
I would like to try to change the brokern ice make lever on the front of the frig. How hard is it and what is involved?
Randy
This is a fairly new model for which i do not have any technical information. (Since we who respond repair things, we know the older stuff well, but the newer stuff, well, not so well)
See if there is a tech sheet with trouble shooting info and error code info inside the bottom panel. Perform the diagnositics and see if that will help.
I suspect you will find you need a new door lock assembly, and maybe a new CCU. Be sure and check the wiring from the CCU to the door lock assembly for any breaks or shorts as that could also be your problem.
Good luck
I have made a plastic part that is 18.99 and send it anywhere with instructions.Im not a repairman but it fixed mine whereas the repair guy couldnt.Its not fixed by replacing the panel.Well it will be but thats thesuper expensive fix.Its much easier than that. In roughly 1 year when it goes back again.
OK Good
I don’t know exactly what you did, or where you did it, but if it works, that’s great.
Thanks for the update!
