Kenmore 80 Drain
kenmore 80 110.72982110 Won't drain or spin. Timer was at off. I tried spin only cycle and water level dropped but no spinning.
Eventually most of the water drained and I could get it to spin but not
drain any further. 1st thing I checked was lid switch. It was OK. Ohm test
switch and jumped wires. Not the switch. I removed the hoses to the pump and could not find any obstruction. This is an old kenmore 80 and I don't want to start replacing parts to find out which one is bad. Do you have any idea what the problem might be?
Sounds like the problem is a bad water pump.
— Begin quote from Gene;609188
  • The water pump [part]AP3138954[/part]
I am going to replace the, pump. You wouldn’t happen to have instructions. If not I will wing it. Thank you.
Water pump suspect. take it out and look inside for broken/worn down impeller blades.
