Kenmore 80 series washer
washer tube is banging up and down when spin cycle disengages and brake should be stopping tube. inspected brake parts and clutch parts with no apparent defects. Should the washer drive block be squeezed onto the shaft with spanner nut. As is the drive block, spanner nut and tube all just lift out with the 7/16 bolt removed. Any suggestions!!!
Yes, the drive block squeezes onto the basket drive tube with the spanner nut. Sounds like your drive block is shot. Check the condition of the two tabs at the top of the basket drive tube. If they are broke off, you will need to replace that as well.
http://www.appliancepartspros.com/whirlpool-washer-drive-block-389140-ap2905773.html
http://www.appliancepartspros.com/whirlpool-basket-drive-and-285792-ap3094539.html
Eric
Thanks… ordered part.
