kenmore 90 series agitator
My kenmore 90 series washer spins but won’t agitate. You can’t turn it either way by hand. When the tub spins clothes get caught in the agitator causing it not to spin unless you take some out and move them away from agitor to sides of tub. Agitator does not spin in spin mode. Coupling is fine. What could b the problem? The washer is a direct drive. MODEL # 110.22922100
Please post your model number off the washer.
Nat
Model 110.22922100
Thanks for the tip. I will try that and see if it works. I have them out and gonna replace them, but I didn’t realize that would cause the bottom agitator to not spin in spin mode.
Did you check the coupler between the motor and the pump?
Nat
Yes, I Checked Coupler Between Motor And Pump And Its Fine. Its Just The Bottom Agitator Agitates Back N Forth Whn Washing But When Ever The Tub Goes In Spin The Bottom Agitator Will Not Spin With The Tub Causing Clothes To Wrap Around Agitator And You Have To Stop It And Move Clothes To Side Of Tub To Get Them Away From Agitator To Finish. And Thats Only Washing A Small Load.
Anybody Have Any Suggestions On What The Problem Could Be? Could It Be Something In The Transmission Or Clutch Causing The Bottom Agitator Not To Spin With The Tub When Its Suppose Too???
Go to searspartsdirect website and you can see a breakdwon of your machine.
Nat
dryer turns on but dont heat. how do i replace the fuses
