Kenmore 90 series washer won't agitate or spin
Since I am man of the house and financially challenged, I have to fix it myself, so any help is greatly appreciated. My Kenmore 90 series washer model# 110.20901 990 won’t agitate or spin, it fills up with water and drains (although not completely) maybe that’s because it won’t spin…anyway I would love any thoughts on what is wrong, what part I need to replace and maybe a how to video…Thanks!!!
If the motor is running but the washer won’t agitate and spin then the problem most likely is a bad motor drive coupling. It is easy to replace and the video bellow will guide you through the whole process.
  • The motor drive coupling [part]AP3963893[/part]
Wow, thank you so much, I will try that!!!
You are welcome. Keep us posted.
Gene, I also have a 90 series, when agitating is the arm supposed to be turning as well? When watching it, it looks as though its just shaking the clothes in place rather than moving them in a circular motion as I thought it used to do? Am I correct in thinking this or no? Thanks for your help…
The top portion of the agitator should move force and back to stir the clothes. If it’s just shaking then the agitator needs repair.
If you need more information, post the complete model number of the washer.
Hi Gene, the model # to my 90 series is 110.26901692 ~ I hope this is a simple fix…
You have to order the agitator repair kit to fix it. The [B]AppliancePartsPros video[/B] will explain in details how to do it.
  • The agitator repair kit [part]AP3094544[/part]
Kenmore won’t wash or spin. It will fill with water and when it hit wash it makes a loud humming noise. Same for spin cycle. Any ideas?
Thank you for any help.
-Christina
What is the full model number?
Eric
MOD: 22422100
SER: CM2280033
TYPE: 111
Top loader heavy duty super capacity
MOD: 22422100
SER: CM2280033
TYPE: 111
Top loader, heavy duty, super capacity
Thanks for any help.
-Christina
Could be a number of things but I would first remove the cabinet and pull the pump off the motor to determine if something may be jamming the pump. Just release the clips on the pump and pull it off, no need to remove the hoses at this point. Now try and see if it will agitate or spin. Here’s a video on removing the cabinet.
Eric
Thanks ill try that
Hello,
I have a Kenmore 90 series washing machine that will no longer spin. When the spin cycle is on it makes a loud buzzing type sound. Model number is listed below. Thanks in advance.
MOD: 23932200
SER: CM1506235
TYPE: 111
