Kenmore 90 srs thump/grind heard when braking down from spin cycle
I have a Kenmore 90 series washer that works completely fine except for this thumping noise heard as the machine winds down from it’s spin cycle. I found a post that instructed to use a little high temp silicone on the inside of the brake drum. I have tried this and it didn’t make any difference. I have also checked the skateboards as s\described in here and they seem to be aligned (I could push lock pins into the holes).
Any advice on what to check next?
I’ve just noted that if I open to door while in spin the knocking starts as the agitator speed and drum speed start to vary. The agitator stops quickly and then then knocking occurs as the drum slows down
You might have a bad drive block that the tub sits on, also check the bottom of the spin basket. Sometimes the filter breaks and scrapes the bottom of the tub.
