I replaced the clutch, coupler and transmission trying to fix a no-spinning problem. After replacing everything the washer worked really well for about a week, now it wont spin again.
The basket is really really hard to turn, so I guessed brakes as I didnt replace them when I did all the other stuff. I just replaced those. Its still not spinning, and the basket is still really hard to turn. It seems to do everything else ok (agitate, fill, drain etc).
Removed moter & trans. When you turn the brake cam it spins freely, but I thought it turned alot easier before it stopped spinning. I could be wrong there though.
So how do I tell if the brakes are seized, and how do I fix it?
