Kenmore Catalyst won't drain after replacing pump
We have replaced the pump on the machine & it still will not drain. Fills, agiates & spins, however when it suppose to drain, water fills in the tub while it is spinning & no water drains. What else could be wrong?
Hello,
Did it show any error code?
If it did, post it.
If it did not, perform the diagnostic tests as instructed in the attached tech sheet and post the results.
