Will not drain, not clogged
The machine will fill, aggitate but it won’t drain. Don’t know if it will spin because it has to drain first. I pulled the pump off and it is not clogged, and seems to be ok. Also when you advance the timer drain you dont hear anything like a pump trying to start.
