No drain BEFORE spin
Not draining after wash cycle but timer continues w/o noise from machine (pump not draining prior to spin). Starts slowly spinning with water in tub and starts draining (pumping) too but not enough water out by end of cycle to spin fast enough. If set to beginning of spin cycle 2 or 3 times water is finaly pumped out and spins "dry" but repeats same process in rinse/spin cycles. What’s going on here?
Make sure the drain hose isn’t jammed into the stand pipe; there needs to be a slight air gap. Look for a clogged or kinked drain hose. If these things check out OK, you may have a clogged pump.
