Kenmore Coldspot getting warmer every day
Top freezer - cool air from working rear fan. Was 40 degrees inside yesterday, 50 degrees inside this morning. Meat starting to thaw.
Icemaker just stopped making ice yesterday (related?). Water line clear.
Bottom refrigerator - not keeping cool. Warming a little more each day.
Compressor too hot to touch. Fan next to compressor seems to work fine (not constant, just spinning as needed I assume).
Condenser coil clean. Vacuumed out all dust.
I’ve been reading the forums online and still am not sure how to determine if this is a relay, overload, freon or compressor issue for this model.
Any ideas are truly appreciated!!
Put a portable fan on the compressor and condenser and see if the temperatures go down. After a few hours, check the evaporator coils, suspect a bad compressor/evaporator leak.
