Hi All,
I have a Kenmore Dishwasher 665-17039400. My original proplem started when I heard a buzz coming from the washer. Then the dispenser door didn’t close no matter what I tried. I purchased a replacement dispenser unit #8558129 and installed it. When I removed the old dispenser I noticed that the little motor or solenoid on the back of the unit may have over heated because the door insulation was stuck to it. The dispenser door closed but after running a wash cycle I noticed that the soap door did not open. I ran it again to verify and again it stayed closed. What am I missing? Is there a fuse or fuseable link between the contraol panel and the dispenser?
Thanks in advance for you help
