My Kenmore dryer has no heat. The fan runs and the power is good from the outlet. The heating element seems to be ok, but there is no voltage going to it. I checked the fuse by the dryer vent and it checks out. Ideas?
Check the thermostats and the thermal fuse. One of them should not have continuity and that will be your problem.
Found it thanks!
Great, glad you got it working.
