kenmore dryer not
Dryer won’t start,I push the start button and nothing happens. Everything was ok and all a sudden it won’t start,can anybody tell me what it might be,or what can I check? Any help will be greatly appreciated!!!
Hi.
Using the multimeter:
First check if there is 240VAC at the outlet.
Next - check the door switch.
Then - open the rear panel and check thermal cut-off and hi-limit thermostats.
The door switch 3406107
The thermostat kit 279816
Thank you. Post the results.
Simon.
