Kenmore elete dishwasher
I have a question. I want to buy parts but not really sure what I should buy. I have to pull out the grinder about every few loads and clean it out. I am not sure if I just need to replace the grinder or if I need to buy the part that causes the grinder to run, there must be some kind of motor? Everything else works fine it just doesn’t grind food. Can anybody help me?
Michelle
Do I need to buy a motor or the impeller assembly kit? Thank you for you help. It is greatly appreciated and I can’t wait to get my dishwasher up and running again.
Michelle
My dishwasher is not draining!:confused: Any suggestions on what to check before I call in the repairman?
First check for clogged, kinked, or restricted drain hose. Does the sink drain freely? Next (this may need to be done by qualified tech) check for power/operation of drain pump.
From what I’ve found researching issues I’ve been having, it seems like that chopper is an achilles heel for these washers (Kenmore branded Whirlpool and Whirlpool). I had a problem a year ago where a piece of a broken glass made it into the chopper and stopped the whole motor from turning. I opened the cover and removed the glass. Now, it seems that the chopper has worn a groove in the shaft and doesn’t spin. I’m ordering the part now (I faked the current one to keep the dishwasher running until the part arrives).
Rick
— Begin quote from Gene;14058
Hi Michelle,
Here are the parts you have to order:
Good luck.
Have a refridgerator that my food (not in the freezer) has started to
freeze. Have had no response with the thermostat controls, no matter
where I set the thermostat. For a one week period the refridgerator
went back to normal cooling. Yesterday my food begin freezing again.
What do I need to do?
Seems like a bad cold control AP3037004 Make sure you get the factory specified part and not a substitut
