Kenmore elite dryer
Dryer won’t run. Has power,all buttons work and light up. When start button is pushed, door lock clicks but dryer does not start. Ran panel diagnostics. Door switch checks out ok. Moisture sensor shows "02" in window rather than "03" which is what instructions say should display. Console switches: all work and beep when pressed; except when pushing start button, "06" is displayed rather than "01" . Any ideas?
First, check the belt. If it’s broken, motor won’t start. If ok, you need to check voltage at P-1 connector on machine control board. Check for 120vac between light blue wire and white wire when you press the start button. If you don’t have it, the control board is bad. If you do have it, check it between light blue and blue wires. If not there, door switch is bad. If you have it there as well, then check the thermal fuse. If thermal fuse is good, check the belt switch.
Eric
