Kenmore Elite Electric Dryer
Any suggestions appreciated.
Kenmore dryer - won’t heat.
Timer good
Circuit board good
Heating Element good
Fuses good
Motor good
Will turn on, run cold for one minute, then shut off. After shutting off, will run while on/off switch depressed, but shuts off when you let up on switch.
Thanks,
davepool
This is an EvenHeat model, notorious for bad control boards. How do you know the board is good?
Eric
Hi Eric,
I bought it new, so I can’t say for sure that it is good.
Thanks,
David
