Kenmore Elite no water in door
I think I caused this while fixing my ice maker. I now get ice, but can’t dispense water through the door. Additionally I can’t get the ice to dispense through the door either. I’m guessing these problems are related and most likely self inflicted by me.
I removed the kick plate and disconnected the quick disconnect and there was no water pressure there. However, when I removed the filter I could hear water flowing within the filter assembly. I’m positive I’m getting water from the supply line to the wall as the ice maker is still making ice.
Any ideas?
OK, after checking the valve, supply line, and even pulling off the dispenser cover on the door and checking the wiring I was still getting nowhere.
So I carefully reassembled it and decided to see if the light in the dispenser worked. It did. And while testing it I noticed a button labeled "Unlock"!
Duh! Problem solved and I do feel like Homer Simpson…
