My water dispenser and ice maker are not getting any water to them.
Both dispenser arms seem to work ok, the compartment light turns on and ice is dispensed ok. I’m just not getting any water out of the water dispenser and the ice maker doesn’t fill with water even though the arm is down.
It’s acting like some valves are bad, the line is frozen, or the filter is clogged.
It just went out last night, and I didn’t have time to do any of my own troubleshooting. However, I know that the filter is less than a month old so I doubt that it’s the problem.
How can I tell if the line is frozen and how do I fix that?
My guess is that a solenoid valve somewhere went out. If I recall correctly, that valve is just on the back of the unit and should be pretty easy to replace, no?
The only other piece to the puzzle is that my ice maker inlet tube had been leaking just a little, resulting in some big chunks of ice frozen together in the back of the bucket. A little annoying, but nothing major.
Any other ideas as to what I should look for?
