Kenmore Elite Refrigerator not cooling
Hello,
You folks helped me not to long ago fix my Kenmorte Dryer. I am hoping you can help me with the refrigerator. This model is the one with the upper section refrigerator with two doors and the lower portion pull out freezer. I noticed yesterday that the freezer section was starting to defrost. well as of today the frezzer has completely defrosted and the refrigerator section is just barely cool air is blowing out of both the freezer and refrigerator vents. I removed the back panel this morning and found the compressor to be hot. not so hot you couldnt put your hand on it but you cant leave it there long. you can here an audiblke Click every so often coming from the compressor. Could this be an easy fix or is the compressor bad??? Please help
Model 596.73509202
Thanks for your help
Sounds like the start relay on the side of compressors has failed and needs to be replaced.
— Begin quote from ApplianceJunk;760301
Sounds like the starter relay on the side of compressors has failed and needs to be replaced.
Do you happen to have a picture of this part or instructions of where to find it on the compressor. Is there a way to test the part?
