what does error code f3 mean
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=911.4698814
911 is a Roper unit made by Whirlpool.
Here is a link to error codes.
Note: This site blocks the link so here it is just remove the XX’s
http://www.repairXXclinic.com/Fault-Codes
Looks like it is probably a bad oven sensor.
Here is a good link on how to check it etc.
http://www.applianceaid.com/elecrange.html
Check out 7, 8 and 21.
I replaced the oven sensor with the part you suggested. It still gives a F3 after about 30 seconds. What do you suggest now?
Did the oven sensor measure bad?
The next part would be the control board (clock).
I cannot find any tech info on this unit so this is just a guess.
I am assuming that the sensor plugs into the clock/control and that the control has the relays to control the elements on it.
Since F3 is a open sensor (infinite ohms) I would check the connectors and tracks on the control board for a crack etc.
Could also be a cold solder joint on the board. They are often a duller grey/silver, may have small holes in the solder or you may be able to see the components leg move in the solder joint.
It looks like the control board is obsolete.
