First off. I cannot find a manual for Model 911 4742003.
Unit will briefly come on and then quit. I’ve reset with no success. Resetting sometimes causes a flashing F1 code.
I also cannot find any info on your unit.
I tried AppliancePartsPros, Sears parts and Whirlpool.
Even tried to Google it and all that came up as an oven was your post.
Please check your model number.
I can tell you that the unit was made by Roper which is owned by Whirlpool.
Roper F1 error codes often point towards a control board problem.
But without finding a tech sheet I cannot confirm this.
Below is what I find;
F0 or F1 or F5 —Failed Electronic Range Control (ERC) —Replace Electronic Range Control/Clock (ERC)
Here is another set
F1 —Analog to Digital Failure —Disconnect for 30 seconds - if display re-appears - replace control
F1 —Safety flip flop —Replace component
F1 —Shorted keypad —Replace component
Your right. The model # is 911 4742993, How do I remove the control panel?
