Kenmore Freezer Door Bottom Hinge
We have a Kemore side by side refrigerator model#SR1087. We purchased it back in May 1991.
It appears the freezer door bottom hinge has broken. The door will not close completely without lifting it when closing. I’m thinking that the hinge must be broken. I went to SearsPartsDirect.com to order the part but Sears parts website came back with the message ‘no repair parts are available for this model.’ I can’t find the model on this site either. What should I do? Is there another model that’s similar and the parts are interchangable? My SR1087 needs help…Please?:slight_smile:
Model# 363.9514710
GOD blesses you for being a great help Gene! I ordered the part moments ago and will let you know how my installation goes…
I was so excited to get the part info I forgot to ask how to install the part. How do I install the bottom door hinge kit AP2063068?
You’re welcome.You did very good job! I’m glad you were able to fix it.
DBXR453ET5WW - GE DRYER - 1997 PURCHASE YEAR
First problem ever with this dryer, just quit heating - it tumbles
  1. checked the household main breakers and hit reset
  2. check for blockage - removed
    I believe the dryer may have overheated - 1st time we have had a blockage as well.
  3. still no heat
Q. Is there a fuse in the dryer that can be reset? AP2042565?
Q. What part or parts should I purchase? - A starting point
Here are the parts I think it could be, but I do not know for sure
so I am looking for some expertise, thank you for your help.
AP2042618
AP2042573
AP2042565
AP2619954
Karen Tennyson
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=DBXR453ET5WW
You may want to take a look in the control console, they like to hide the wiring diagram there. Trying to find a GE wiring diagram on the internet is difficult.
At the top of the list would be the thermal fuse.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
