Kenmore Fridge Door
Hello,
We have a kenmore fridge with the freezer at the bottom. Not sure on how to explain this - but the fridge door no longer shuts tight without some force. Before it used to have a 6" gap when teh door had some tension and then automatically shut tight with out effor. Our bottom door is okay.
Is this the hingeds?
Thanks for any insight
Hello,
Double checked the Model # and it’s correct. This is a Sears model and I’m from Canada.
I did find a manual on line - but it doesn’t mention or show anything about cams.
Here’s the manual I found online for my Fridge. I’m not sure what part is the cam if there is one for my model.
http://www.appliancefactoryparts.com/content/pdfs/129970-8.pdf
I also could not find any cams so it looks like they do not use them on this unit.
I did find a part they called a stopper (243) perhaps something is wrong with that.
Also check the gasket/seal on the hinge side of the door. Sometimes they can grab and cause problems. A light coating of white lithium grease or vaseline usually fixes this.
Other than the above I am afraid I am out of ideas.
