My fan in my Kenmore side by side will not turn off. I have turned the setting down to "1" and it still keeps running. I suspect the thermistor to be bad, but can not locate it. Can you help me???
If all the fans are running plus the compressor, you might have refrigeration problems assuming the condenser coils are not clogged. I assume your temperatures are near "normal"
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=106-52552100
See the attachment for the wiring diagram.
If you go to the Sears parts site, they have part breakdown diagrams.
Unfortunately they do not share these with other parts vendors.
The thermistors are:
Item 23 in the Refrigerator Liner section
Item 9 in the Air Flow section
