Kenmore front load won't agitate or spin
Looking for help on Kenmore front load washer. Start it, fills with water and then ‘stops’ meaning it doesn’t agitate when it’s supposed to. If you advance the timer to the spin cycle the drum empties of water but no spin.
Took the back off and removed the belt like the sheet says, motor did not turn. Went to check some of the wires but my multimeter needs a new fuse. Was wondering if this might be an obvious one for someone to diagnose?
I’m having a similar problem: when i start a load my washer fills up with water and then just stops. From what I’ve read in other threads, it could be the lid switch.
There is a diagnostic sheet behind the front panel. You can fix this if you have a meter to check things.
