Kenmore front loader won't drain or spin
I have one of the infamous front loading Kenmores with the spider arm assembly issue. Fixed that a few months ago and now the unit will not drain or spin. It rotates both ways during the wash cycles so I know the motor and the belt are fine.
Any ideas?
You may want to check the door lock/switch assembly. The instructions should be in the tech sheet behind the front bottom panel.
Here is the Wiring diagram.
The disassembly instructions are attached to the reply.
  • The door lock/switch assembly [part]AP4455026[/part]
