Kenmore Laundry Center drum not aligned and clothes getting stuck in gap
I’m not too mechanically inclined but I wondered if there could be a simple fix to rid of the gap inside the drum. It seems that there is a bad seal or a misalignment. Clothes have been getting stuck. What can I do about this and how much time and money might it cost?
had it been squealing for awhile then quit? at any rate I would replace the rear bearing and front drum felt bearing if you hire someone it would run about 250.00 Do it your self and it’s not an easy fix you could save half that
