Kenmore Model 66812 694 dryer parts?
I have a Kenmore dryer that started squealing and found a repair kit that should fix the problem but it doesn’t list my model number.
http://www.appliancepartspros.com/part_details.aspx?part_id=3131942
Can someone please tell me if this will fit? The dryer is:
Kenmore 80 series
Model/Stock # 66812964 66812
S/N MH1305545
Any assistance would be appreciated!
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=5403431
I believe your actual model number is 110.66812694
Unless you can get confirmation on the kit being the correct I would order the individual parts.
Well I replaced the idler, rollers and belt and still have the squeak. When I had it apart, I cleaned everything up good. When turning the motor by hand I did notice that the squeak was coming from the motor, so I guess that’s next on my replacement list? Anyone have any tips for motor replacement? Is there a motor bearing kit or is it best just to replace the motor?
Anyone have a .pdf manual for this model?
