Kenmore Oven Codes
I Have an error code f7,nothing but the clock works. Oven about 10 years old
Most likely the problem is a stuck key on the key panel or a shorted control panel ribbon cable. The correction is to replace the control panel. If you need the correct part number then post the color of the control panel.
The white control panel AP3155843
my igniter turner on things for one of my burners is not working and needs to be replaced. need help to get it out, and install a new one. Thanx Bob
ok when i turn the right front burner, the left rear burner igniter starts to spark. but doesn’t ignite the right front. all other burners work as their supposed too.
— Begin quote from Biker Bob;264094
Biker Bob,
Which "igniter turner on thing" are you attempting to replace ?
Spark igniter (on the burner).
Igniter switch (on the burner valve).
Ignition module (under the cooktop).
Do you have a part number ?
How about a description of your problem ,
We’re always willing to give you a more efficient way to diagnose and possible parts needs if we know what’s wrong.
:cool: :cool: :cool:
