I have a Kenmore flat top oven model 665.92023101. The element on light was stuck on so I replaced the infinite switch. The switch didn’t solve the problem so I looked at the heating element and noticed a connector had come loose. I reconnected it and the light went off. The problem I have now is whenever I turn that burner on, it is always on high heat regardless of where the dial is set. Any ideas?
Related topics
Kenmore Range flat top burner stays on high | 3 | 4344 | July 16, 2012 | |
flat top stove | 3 | 925 | February 9, 2012 | |
Kenmore Cooktop Element Not Working | 3 | 2276 | July 30, 2009 | |
Kenmore range won't turn off | 7 | 4945 | August 12, 2010 | |
Kenmore Glass top single burner out | 1 | 2451 | October 12, 2009 |
