Kenmore Refrigerator Dispenser Auger not turning
I have a Kenmore side by side model # 363.59552990
The ice maker makes ice and fills the ice tray full with no issues. The problem is dispensing the ice. The auger motor does not turn or make a sound. The solenoid flap which should open as well does not. The water will dispense when the switch on the control panel is in the chilled water and crushed ice position. But the light only illuminates when the switch is in the crushed ice position. I have replaced the auger motor and dispenser control board. The dispenser switch has been checked for continuity. Need to know where to go from here. I have a digital meter to check voltages and continuity. To get the ice dispenser to function properly.
Thanks in advanced
anderrd
