kenmore side by side no water from door, ice dispenser works fine
Hello,
I have a Kenmore side by side model #106.51522100, and the water has stopped coming out of the dispenser. The water is going to the ice maker just fine. I thought the problem was with the water valve in the back, but I have replaced it, and it is still not working. With the outlet tube unplugged, I depress the dispenser and receive no water out of the valve. Can someone tell me what the problem is? I have confirmed water going to the valve as well as to and from the filter to the valve. Is there a switch that could have gone bad at the dispenser?:eek:
thanks,
matt
