Kenmore washer leaking water on transmission
Model #11082874120, direct drive, series 70. It appears it is leaking from the drive shaft. Has anyone replaced the Washer Bearing and Seal Kit Part 285203? What tools or techniques are needed to replace successfully?
Read more: http://www.appliancepartspros.com/whirlpool-bearing-and-seal-285203-ap3020440.html#ixzz4D5tVOQSE
Thanks.
